Brief Description: 2. Started to lay up aft lower windscreen
I carefully taped the line on the canopy that will form the aft edge of the windscreen fairing then taped up any place I thought resin might creep to. I planned to do a fair bit of the skirt today but after missing up some resin and flox it was not lying how I wanted it to, I also realized I should have laid a base layer of cloth. I aborted the attempt for the day and will sand things and start over.
All prepaired
I abotred after forgetting to lay a layer of cloth, I screpped most off an left to cure.
