RVGator
Date:  7-19-2011
Number of Hours:  5.50
Brief Description:  More work on the skirt
Can you believe I spent the entire day still working on the canopy skirt. I started by refining the aft end a bit more, then I used a light on the inside to mark the edge of the canopy glue line. Not feeling confident I drew a parallel line 1/8 “high and made my first cut there. It is a good thing too because I think this will be my final trim. The Sika glue line was a bit wavy so this line fits so that from the outside you can’t see the waves, you can from the inside, my though is I will paint the skirt black above the lower edge of the canopy so it will blend in with the black Sika adhesive.
After the trim of the upper lines I refit the skirt and messed more with the aft fit, I just did not like how it was lying on the fuselage. I was basically happy but still had a bit of pucker on the “S” curve up the side of the fuselage. I tried some heat gun magic but did not like how that turned out. Pulling and tugging on the aft ends I found that if I pulled up and in the puck would go away. I did this with both sides and made a new trim line for the aft seam and now I am really happy. The right side is perfect but the left still has a bit of a bow but I can live with this, I plan to put a slurry on the underside and close the canopy and let it set this should give me a nice tight seal around the edges.
Now I need to decide where to trim the front edge of the skirt and how I want it to transition to the windscreen. I have a trip tomorrow and then Anita is riding in a horse show this weekend, I might get one more day of work in before my end of month trip, so much for getting the plane to the hanger this month.
Nice tight fit on the right
You can just make out the pucker on the left
When you stand back not so bad!
