I leave tonight on a trip but picked up the Loctite I needed so I installed the fuel control bracket and set the torque to 110 in lbs. I really did not have a productive month in June I hope to change that this month. I have a week of vacation and I dropped another trip so I have lots of time off this month. I have the size throttle and mixture cables I need as well as the purge valve cable to I hope to get a lot accomplished this month.
The goal is to finish up the cables then turn towards the canopy glass work which means fitting the canopy skirt then riveting the top skin in place. With that done I can fit the windscreen, and then the fiberglass work around the windscreen. After that the plane will be road worthy and I will get it to the airport, so big goal do the above and move to the hanger.
