Forgive me but I am catching up on the log entries that I should have done a week ago. My fuel servo should be back after my next trip so before I leave I thought I should get the tail pipes where they need to be. I played with the angle of the pipes through the limited opening until I was happy with them. I then organized the hardware used to hang the exhaust tail pipes.
When I was working on the tail pipes I discovered a small bit of oil at the bottom of the sump. Tracing it up the engine it was leaking from the uncapped AN4 elbow that feeds the oil pressure sender. I installed an torque the oil pressure sender line so this should stop the leak. This fitting is at the top of the accessory case and I was surprised that with no pressure oil would leak from here. I had pushed on and off the prop hug plastic cap so now I think I might have made enough pressure to push some oil around.
Exhaust hanger hardware
This fitting was not capped and leaked a little oil, line now hooked up to prevent the leak.
