After getting the floor modification done I turned back to the electrical. I organized and tied some wires that run along the back of the circuit breaker panel; most of these wires connect to the switches on the right console. I also started to sort out how to run the main bus feed wire. I have an issue in that the batter contact post is really too short to connect two lugs, I will have to research that one.
