I have to leave on a trip tomorrow so I did not do much work today. I started to see where I might run wires for the LED strip lights I will be using for interior lighting. The LED strips come wired with automobile grade wires; the company that sells the LED strips also sells connectors so I decided I would put off work on the lights until I can order the connectors then wire them up with aircraft grade wire.
Then next thing I worked on was locating the Safety Trim controller. I had originally planned to put in the area with the battery but then got the idea of putting it under the front seat pan. This seems like a better location since it most of the wires from the control stick connect to the trim controller
Upper half of seat pan show unside down with the trim contoller in proposed location
