After I decided roughly where things should go, I was going to drill some holes for the wires to exit the fuselage and run out to the wings. The plans show a hole fairly close to the aileron push rod hole. I planned to install boot over the aileron pushrods to keep the cold air out so I figured I better get the rings that hold the boots made so I can de-conflict the wire run hole from the aileron boot ring. I bought a kit a very long time ago with some boots made of black rip-stop material, so all I needed to do was make a ring. I made two rings and then drilled and clecoed them to the fuselage. I ran out of time, I have to go back to work tomorrow so that is it for this month.
It has been a short month; there have been a lot of family issues to take care of so with any luck next month will be more productive.
