Brians RV-10 Construction
Date:  9-7-2006
Number of Hours:  1.00
Brief Description:  EIS Returned from GRT
Got my upgraded EIS back today! The great folks at GRT recalibrated the unit for the Chelton Sport (SV-10).Here is the description on the invoice:"Upgrades: Sport SW, added adjustable backlight, upgraded crystal, new fuel flow setup (sw config only).""Other: Bench test unit to verify proper operation and calibration accuracy. New SW working, backlight working, f-flow working. Unit is within all GRT specs and tolerances."As you can see by the photo, they also supplied a newcable assembly. Total cost: $50...no complaining here!When I spoke to Sandy on the phone the other day I also asked her to add the current sensor and stainless fuel pressure sensor. I had the low pressure sensor that came with it; I assume this was because the previous owner was going with a carburated engine.So in the end I now have a up-to-date unit that will work with the Chelton's and still came in under $1300.00 for the entire package!
GRT Engine Information System, new SS fuel pressure sensor, current sensor
