Brief Description: Pitot tube, roll servo, wing tips
Today I worked on little things to get the airplane ready for its inspection. I installed the pitot tube. I checked all the jamb nuts to make sure they had been tightened. I also put torque seal/nail polish on all of them once I had checked them. I adjusted the roll servo and tightened all the hardware for that. I installed installed the wing tips and final drilled and countersunk that attach screw holes for the lens covers and installed them. Finally, I worked on installing the floors. I had to drill out some rivets that had been installed through the spacers and nut plates at the front of the floor panels. Then I clecoed in the main floor panels.
