Ron Web Site
Date:  1-23-2024
Number of Hours:  7.80
Manual Reference:  N/A
Brief Description:  Interior, Transponder and Static Test, Rear Stick
Today I continued working on finishing up minor miscellaneous things. I started the day by riveting in the floors. I started out using a hand pop riveter and finished using a pneumatic pop riveter. That made things much easier! After lunch the pitot/static/transponder test folks arrived. Everything passed with no problem. I was also able to calibrate both the Mini and Horizon altimeters. At the end of the day I shortened the rear stick so that it wouldn't make contact with the front seat and also put in a set screw to keep the grip in place.
