Brief Description: 2nd Day Entry Safety Wire AST Hinge Pins
Secured the left and right AST Assemblies together at the control horns using a AN525-8R8 screw, a NA1149FN832P Washer, and a AN365-832A nut per figure 3 same page. Rotated the two hinge pins so that the bent ends lay against the Stabilator Assembly and fastened the bent ends of both hinge pins with safety wire (.032 diameter) through the holes in the stabilator assembly per figure 3 call out A-A and twisted the safety wire on inboard side of Stabilator Assembly.
