Brief Description: Continuation of previous log entry
Riveted the F-1281-L & -R Lower Left and Right Skins to the bottom left and right skins leaving all remaining holes open in the lower left and right skins using LP4-3 rivets.
Turned the Assembly over so the frames are pointing up and supported the assembly on two saw horses positioned under the F-1208 and F-1210 frames.
Cleco'ed the F-1211 Assembly to the aft end of the tail cone structure as shown in figure 1 reference page.
Sprayed the inside of the assembly with Zinc Phosphate Aviation Primer
