Brief Description: Fit Stabilator Assembly to F-1211 Assembly
Used (2) AN4-12A bolts with (6), (3) on each side, AN960-416L Washers to minimize lateral play and prevent binding. Each bolt was inserted first into a washer, then through the bracket and another washer, then the bearing on the F-1211 Assembly and finally another washer exiting the bearing. Washers on either side of the bearings were then super glued in place and the AN4-12A and first washer were left in the Stabilatorstabilator after removing the F-1211 Assembly.
