Riveted remainder of rivets in F-1211A fuselage bulkhead and F-1211B bulkhead doubler using (2) AN470AD4-6 and (3) AN426AD4-4 Completing the F-1211 Assembly.
Revited (8) K1000-3 nutplates to the F-1211 Assembly using (8) AN426AD3-45 and (8) CCR-264SS-3-2 rivets per Figure 2 on ref page.
Cleco'ed the F-1211C L&R Hinge Brackets and the VA-146 Flange Bearings to the F-1211 Assembly per Figure 3 on the ref page.
Final Drilled #30 (12) holes, (6) left, (6) right, common to the F-1211C L&R Brackets, the VA-146 Flange Bearings, and the F-1211 Assembly. Disassembled, deburred, cleared away chips and re-cleco'ed in place.
Riveted the F-1211C L&R Hinge Brackets and the VA-146 Flange Bearings to the F-1211 Assembly per figure 3 same page.
Inserted the snap bushing SB375-4 into the F1211 Assembly per figure 3 same page.
Primed both sides with Zinc Phosphate Aviation Primer.
