Brief Description: Self-etching primer on the fwd fuse/rudder
In preparation for paint I sprayed the fwd fuselage where I plan to put paint and the rudder with self etching primer -7220. I didn't alot of taping prior to spraying and then roughed up and cleaned the surfaces. Did some garage rearranging/cleaning since the airplane was outside. Also installed the inspection covers on the bottom of the right wing in preparation for polishing - much easier to do the wing bottoms in the wing rack.
The next nice day I get I can put on some high-build primer and sand.
Lots of taping
The gray on top bottom and sides - not much really, but the prep is the hardest part
