Brent s RV-8 Project N784DE
Date:  12-24-2010
Number of Hours:  1.70
Brief Description:  Baffling #33 + (engine attach hardware/oil filter)
Jumped around a bit this morning.
-Finished riveting the rear baffling together at the job near the oil cooler. Had to reinstall the oil cooler
-Bolted the rear baffling back into place
-Drilled the left rear corner rivet holes to #30. I'll use cleco's for now incase I need to disassemble something - there are easy to get to at the end.
-Turned my attention to the engine attach hardware. Need to verify torque and put in the cotter keys. I got the torqueing done and I want to double check AC23-13 on the proper cotter pin installation before I finish.
-Moved to the oil filter install - my spacer (3/4") from Vans. Removed the 1/4-20 stud from the accessory case and started running a tap into the 4 holes per the instructions when I ran out of time.
Merry Christmas to all!
Riveting done
Riveting done
