-Since my order of Aeroquip 45 degree fittings for 2 of my -10 oil lines that connect to the sump and interfer with the engine mount. I removed the straight fittings and replaced with the new ones. Test fit good. I need to remove them and clean them out with solvent, but I'll leave them in place to account for them when I install other FWF stuff. Also had to order a Raven horizontal sump swivel fitting since that too it tight against the engine mount - sheesh! So much for inverted oil, what a pain! I better fly upside down abunch to justify this! Oh well, onward and upward!
The angle I shot this makes it look tight, It's not.
