Brent s RV-8 Project N784DE
Date:  11-23-2010
Number of Hours:  1.60
Brief Description:  Baffling #27
-Cut hole for governor oil line in the right inlet ramp. It was a pain because the hole interfered with one of the mounting brackets underneath the ramp. After several trim, fit - trim, fit iterations it finally fit good.
-Located the cabin heat inlet hole on the right inlet ramp. Marked it and pilot drilled the hole for the hole cutter tool.
