Brent s RV-8 Project N784DE
Date:  11-20-2010
Number of Hours:  3.60
Brief Description:  Baffling #24
-Bonded the upper cowl inlet ramps in place.
-Finished drilling the airseal material to the baffling
-Installed airseal onto the right inlet ramp - unfortunatley I screw'd up and my holes moved into the edge - I like fitting it to the cowl better anyway like the left side.
-Fitted the airseal to the left inlet. Fab'd a reinforcement/backing strip of .020 to help reinforce the rivets.
-Did some fitting of the cowl - need to work on getting the airseal some 'memory' so it lays down properly.
Inlet ramps flox'd into place
Airseal in place all the way around
Airseal cleco'd to the cowl to test fit
