Brief Description: Oil pressure line complete and manifold mounted
Permanantly mounted the sensor manifold - I'm only using one part of it. I installed the plug in the unused port on the oil pressure part of it - used Permatex #2. I then installed the ss line on the aluminum 90 AN fitting with fuel lube. I spent some time looking for where the manifold pressure guage pulls from the engine. The plans say on the #3 cylinder, but I couldn't find it -more research required.
