Brent s RV-8 Project N784DE
Date:  5-23-2010
Number of Hours:  0.90
Brief Description:  Cabin heat mixing box
-Since I upgraded to a SS mixing box, it's actually alot different from the plans so I had to think through the mounting and actuation. Once that was done, I drilled the holes to install it, leaving permenant installation until later to make room for other work.
Here's the ss mixing box for cabin heat
Here's where it mounts. 2
Here's where it mounts. 2" hole was pre-punched into the lower left side of the firewall
