-Started getting serious about wiring up the flood light system -Solder'd 2 diodes to the 22awg wire that will power the different dual switched lights in the airplane (panel and maplights). -Ran wire for the forward baggage lights and the rear map light. I used PIDG splice connectors where I need to branch off to power another light like in the case of the 2 forward baggage lights.
Getting ready to solder a diode for the flood light circuit.
Here you can see the blue shrink wrap is a diode and then is splice off to power the fwd bagg lgts.
The hole is where the rt fwd bagg lgt goes and the hot wire from flood coming in and going on
