Brent s RV-8 Project N784DE
Date:  1-7-2010
Number of Hours:  0.70
Brief Description:  Fuel System install #2
Worked on plumbing the right fuel tank line that runs across the fuselage along the front of the spar to the fuel selector valve. Still need to tweak it alittle around the fuel valve and work the bends where it exits the fuse.
Right tank line flared and loosely fitted to the valve to figure out the geometry
Here you can see the fuel line running along the front of the spar
