-Mixed up some flox and resin into a slurry and added it to the left front skirt and alittle along the seam along the aft junction. Most of it will get trimmed away. -Made a paper template for the remaining holes in the canopy frame so I can duplicate them on the skirt. Left side done, but right side needs to be done and the holes need to be drilled in the skirt.
Slurry applied to the buildup on the left side of the skirt
Just alittle bit back here.
Template for the holes that angle up from the lower frame to the upper frame.
