Finsihed up the center canopy rail this morning. -Riveted the remaining 3/32 rivets in the center rail -Carefully located the center of the turtle deck F825 where the rail will be mounted. -Marked the centerline of the F825 and the center rail. -Scratched my head to figure out how far into the canopy recepticle the rail should go. Finally noted a very small detail in the drawing that showed where it goes relative to the teflon block. -Taped the rail in place, measured and re-measured. -Drilled the #6 screw holes in the F825 using the rail as the guide with #27 bit. -Removed the rail and deburred the holes in F825 and removed the plastic. -Mounted the rail to F825 using the fwd 3 screws. I still need to locate the most forward screw hole that goes through the canopy recepticle, but I'll do that later once the teflon is permenantly mounted so I don't have some kind of interfereance.
Squeesing the rivets through C804 and C805 (the rail looks bent at this angle but its not).
Drilling the holes in F825 using the center rail as the guide.
