Brent s RV-8 Project N784DE
Date:  7-29-2011
Number of Hours:  1.40
Brief Description:  Heat shield, oil filter, snorkel, oil, wingtip scr
-Added a small heat shield to the exhaust to protect the aluminum drain line off the sniffle valve
-Safetied the snorkel to throttlebody bolts
-Screwed the snorkel to baffling bolts in
-Installed the oil filter per the mfg procedures and safetied
-Put in 6 qts of Aeroshell 100
-Installed screws into the left wingtip. Found one hole didn't have a nutplate - fixed that.
Air filter installed
Heat shield for sniffle valve drain line
Oil filter installed and safetied
