Brent s RV-8 Project N784DE
Date:  4-17-2011
Number of Hours:  4.50
Brief Description:  Wing attach details #4
-Worked on relieving the flaps around the fuselage
-Installed the flap actuator weldment and motor - those teflon blocks are a pain to install sometimes.
-Worked on the right flap, relieved the flap rod hole in the fuselage slightly to prevent contact - more to do on the flap actuation, but since I don't have my ailerons on I can't determine flaps 0 degrees.
-Worked on the left and right wing fairings.
Flaps down (right one only)
Flap actuator installed
Using the mirror to make sure there was no contact as the flaps travel up and down
