Brent s RV-8 Project N784DE
Date:  8-10-2010
Number of Hours:  2.60
Brief Description:  Spinner #3
-I mounted the spinner back on the plane and fitted it up and checked for wobble.
-Removed the cowl to allow more room to work on the spinner and backplate
-After some adjustments I used cleco clamps to hold it firmly in place
-Drilled the backing plate attach holes (14) with #30 drill
-Layed out the support plate holes and drilled with #30 (6)
-Countersunk the support plate holes for flush #8 screws
-Drilled out all the holes to #19 for #8 screws
-Deburred all the holes in the metal parts
-Started attaching nutplates to the support plate when I ran out of time
Spinner clamped into place-point of no return
All 20 holes drilled evenly spaced across the circumference
