Brent s RV-8 Project N784DE
Date:  8-7-2010
Number of Hours:  4.40
Brief Description:  Cowling #13
-Trimmed oil door with dremel
-Sanded the opening on the cowling to get a better fit
-Did final fitting and sanding on the oil door.
-Drilled holes for latch and cleco'd on the camloc latch
-Located hinge and drilled holes in door and cowl
-Test fit everything. Needed to slim the hinge slightly to reduce a bulb in the back of the door
-Also put the heat gun on the door - that didn't help much
-Deburred and c/s as necessary
-Riveted the latch and hinge
-Marked and trimmed the extra material that I added to the bottom of the lower cowl on the right side
-Trimmed some of the extra material on the lower cowl around the inlets
-Drilled out bottom hinges and replaced with solid .035 strips that will accomodate nutplates - re-riveted.
-Reinstalled lower cowl
-Reinstalled upper cowl
-Test fit the cowl and the pin retain covers - the left one needs some work (not setting level in the recess)
50 hrs on the cowl at this point
Oil door with hidden hinge (slight bulge int the aft edge I need to work out)
Open view with the hidden hinge from Nonstop aviation
Cowl pin retainer cover installed
