Brent s RV-8 Project N784DE
Date:  8-5-2010
Number of Hours:  1.60
Brief Description:  Cowling #11
-Removed the cowl pin retainer cover layup from the cowl (had mylar between the two so they wouldn't stick).
-Trimmed out the covers with tin snips and sanding
-Marked off the openings in the cowl
-Used a hole saw to get started and then a rotary file to trim the holes open
-Layed up fiberglass on the inside of the cowl to allow for nutplates for the screws that will hole the covers
Cover piece after popping it off the cowl
Teardrop holes cut - not hinge is exposed to help support the cover
Cover inlayed into the cowl for a flush fit
