Brent s RV-8 Project N784DE
Date:  7-27-2010
Number of Hours:  2.60
Brief Description:  Cowling #2
-Did some additional trimming to the lower cowling
-Drilled #30 the holes that will eventually hold 3 screws on each side of the spinner inside the intake (attacheds the top and bottom cowl at the spinner. This was done with the two cowls mated on the ground
-Put the top cowl in place and spaced it on the spinner with 1/4" of clearance and marked it for trimming to the firewall.
-Trimmed the aft end of the top cowl
-Cut the hinges sections for the top cowl at the firewall
Cowling fun.....the color of peptal bismal  is appropriate
Drilled the screw holes behind the spinner (cleco's)
Trimming the aft (firewall) end of the top cowl
