Brent s RV-8 Project N784DE
Date:  7-26-2010
Number of Hours:  5.60
Brief Description:  Cowling #1
-This is one of those categories that will likely have a hundred entries.
I spent alot of the time just trying to figure out how to start knowing I needed to proceed carefully. Fiberglass is forgiving, but I wanted to avoid the Oh crap moments.
-Cut out the oil door opening
-Fitted the upper and lower together and contemplated my next move.
-Trimmed the lower cowl around the intakes
-Trial fitted the upper on the airplane
-Added the lower to the airplane
-Noted the upper needs some trimming as the opening isn't round and droops down below the spinner excessively.
-Refit back on the airplane - better fit
-Clamped the halves together off the airplane in preparation for drilling the 3 screw holes in the inboard wall (behind the spinner) of the intakes.
