-Marked where the right wing tip pos/strobe assembly will go -Drilled the center hole and two screw attach holes -Put on clay and carved out the shape to match the left side as close as possible -Layed up 3 layers of BID with west systems epoxy -Put on peel ply and removed once it dried - about 6 hrs later
Came out pretty good so far. Next session I'll put on the slurry of microballoons and west systems epoxy.
Drilled the holes for the lgt assembly
Working the clay - the ss ruler is taped in place to provide ref to the lens
