-Spent most of the time carefully sanding the mico on the wing tip cutout. -Drilled the holes for the fasterns that hold the pos/strobes light assembly in place -Removed the lens cover for the assembly -Drilled holes for the LED wires and Strobe wires
Pos/strobe assembly - strobe removed to avoid damage during fitting
