-Squared up the wheel pants (measured equal distance from centerline and laser leveled) -Had to remove and trim the right one alittle more -Reinstalled the right pant -Drilled the inboard mount holes. Came out pretty good. -Final drilled the #6 screw holes -Final drilled the #8 screw holes -Countersunk the #6 and #8 screw holes in the glass -Removed the pants -Drilled aft half of the pants for #6 nutplates -Installed nutplates on the same -Drilled the inboard bracket for nutplates and deburred -Installed nutplates on the same
I'm planning to install the pants next session and double check tire and caliper spacing and the start working on the lower intersection fairing.
