Brent s RV-8 Project N784DE
Date:  7-13-2010
Number of Hours:  2.60
Brief Description:  Wheel pants #5
-Trimed and fitted the right wheel pant to match the left. I ended up having to redo the holes I drilled into the outer support bracket twice trying to get that one aligned properly - I thought the second one would be easier? Thank goodness it's fiberglass and not aluminum in this case. Anyway, I have it like I want it and I have everything layed out to square them up and drill the inboard brackets which will set the final horizontal and vertical alignment.
Right wheel pant on and drilled (outboard bracket)
Both pants shown with plumb bob and centerline
