Now that I have most of the smoke oil system I really need to get it in place so I can put the battery tray back in so I can light up my panel - I know everything is related. Spent most of this session head scratchin'. I worked on figuring out some of the plumbing. I ended up raising the tank 1/2" because it was very very close to rubbing the strobe pwr pack and the feed fitting was interfering with the longeron. I used 2 pieces of hardwood to support the tank and that raised it 1/2". I then worked out the restrictor valve (still haven't figured out where it goes or plumbed it). Next is to locate where the valve, filter and pump will go.
