Went to work on the 1" x 1" x 1/8" angles that will support the smoke oil tank between the middle longerons. I cut the aft brace and located the bolt holes that will tie the brace to the longerons. I drilled the holes in the braces and marked out the hole locations on the longerons. Started to drill the right longeron with my 90 degree attach - apparently my 1/4" bit isn't the sharpest. Anyway - I ran out of time so more next session.
My workshop for the time being - at least I have carpet!
