Brief Description: Parking Brake #7 plus Brake lines
I removed the cable from it's sheath and lubed it up with lithium grease. Then I installed the adel clamp that attached the cable to the firewall. I began the process of mounting the valve and wasted at least a half hour looking for an AN-3-11A bolt but only found one and due to the tight quarters that is the only bolts that will fit. I had to go to Lane Av and get a couple today. I then moved on to installing the 90 AN elbows in the F822 cabin floor inside the gear tower. This will be where the brake lines exit the fuselage and connect to the landing gear (my Grove gear legs have integral brake lines.
Slide this piece of 1/4" fuel line to keep the coil sheath from chaffing the skins.
I'm holding part of the parking brake mounting bracketry - I need 2 AN3-11a bolts to attach this...
