Worked on the C/B subpanel this morning. Finished up the cardboard mockup. -Cut out the .025 with tin snips. -Fabricated an angle out of .025 to anchor the bottom of the subpanel to the right console surface. -Layed out the rivet holes for attaching the angle to the console and drilled -Layed out the screw holes for attaching the subpanel to the angle and to the right switch panel
Here's the subpanel in position prior to drilling
Angle fabricated using .025 on the cheap harbor freight brake.
