Spent the first :10 minutes drilling holes in the bulkhead to route the pitot line. I need a smaller grommet for one of the pre-punched holes than what I have so I moved on to modifying the baggage shelf to accomodate the static ports and lines. I shortened the shelf and rebent the edge to allow for the static ports. Also, I drilled out the rivets in the front support of the baggage shelf so I could put in screws and nuts as to make it removable. I realized with the turtle deck on I wouldn't be able to install the new baggage shelf with the support in place.
Drilled these holes and installed the grommet for the (white) static line
Trimmed and rebent the aft bagg shefl to allow for the static system installation.
Drilled the rivets out of the cross brace for the bagg shelf to make it removable.
