-Dimpled the 2 rivet holes each side for the static port mounting. -Rivetd the ports onto the fuse. It was hard to shoot as the gun couldn't center because the port stuck out. Had to drill out one rivet but it turned out fine. -Attached the quick disconnect fittings to the ports from safeair. -Drilled attach screw hole for the T fitting and deburred -Fabricated a spacer for the T fitting so it clears the rivets that are nearby. -Mounted the T fitting -Measured and cut the plastic line -Ty wrapped to the holes in the F807 per the plans.
Still need to route the line up the left side under the top longeron.
