Well I did a good job of priming everything prior to assembly expect the fwd floor and the gear towers. The insides are primed but I left the exterior anticpating expoxy primer at later date, but I have decided that the 7220 is durable and the right texture and color for me so now I need to get it done. I removed the control sticks and column Removed the gear tower access plates Scuffed and cleaned the floor
Next I will need to tape off the spar (gold anodized), firewall, and weldments.
This is the area that needs primed, floor and gear towers.
I also match drilled and hole deburred the shoulder harness doublers.
