Contineud to work on the seat floors. Cleco'd the floorboards back into place and then put the flap assembly in and match drilled the front bolt per the plans - worked great. Then I moved to separating the stiffners that are delivered as one piece per the plans. Then I deburred the edges of those and cleco'd one to the mid floor board along with another structural angle and put the whole thing in the fuselage. Then I match drilled #19 the holes that go into one of the skin supports F805 before I ran out of time.
Drilling the forward hole in the left flap bearing block using the 90 degree drill attachment
