Brent s RV-8 Project N784DE
Date:  12-6-2008
Number of Hours:  2.10
Manual Reference:  8-48
Brief Description:  Fwd bottom skins #2
Got alot done on the forward skins today. I trimmed around the larger F805 brackets on the Grove gear for both the F851s (L/R) and the F850. It was a iterative process, but I'm happy with the results that will be summarily hidden under the gear upper intersection fairling. I then match drilled per the plans after cleco'ing the 3 skin panels onto the fuselage.
Here I am trimming the F850 panel to fit around the grove gear bracket.
Here's the left main gear F851 cut out.
Skins are on and drilled out and ready to deburr, dimple, and prime.
