Brent s RV-8 Project N784DE
Date:  11-22-2008
Number of Hours:  1.30
Manual Reference:  8-45
Brief Description:  Front Seat back #1
Since I need to get my wings out to the wing stands to make room for the landing gear measurements, I move to the seat back since those go together separate from the fuselage (which is upside down at the moment).
-Separated F832BL-1 & R-1 (vertical support angles) with the dremel - wouldn't fit on the bandsaw
-Trimed the bottom corner off the F832Bs
-Deburred the cut areas on the F832Bs
-Separated the F832C seatback angles (horizontal)
-Deburred the area that was separated (3M wheel)
-Removed the tabs from the seatback per the plans (dremel with thin cutoff wheel)
-Cut a piece of P3 hinge to 10" leaving the pin at 11" for removal
-Marked and drilled 2 1/8" locating holes in the hinge per the plans
-Cleco'd the hinge to the seat back and drilled the opposite end 1/8 hole
-Cleco'd the support angles, horizontal and vertical, to the seat back
Good progress for a little more than an hours' work.
All of the front seatback parts.
Trimming the F832B per the plans
All of the pieces are together in close formation.
