Didn't get much done for a Sunday, but I did get started match and finish drilling the fuselage. Per the plans I started with the fwd skin where it attaches to the lower longeron. Dulled a couple of bits on the motor mount holes, but I have plenty. Got both the left and right side done. The plans says to be sure to stay 90 degrees to the skins so I used the drill cup - if you are building this is a MUST have item and they're not much money.
Match driling the left side forward skin to the lower longeron.
