Brief Description: Adding Tailcone to FWD Fuselage #5
Well I spent an hour clamping the upper longeron into position to my satisfaction. It is still alittle resistant around the gear towers but I used some light weight bar clamps to get it 99% of the way and I can pull it in with my hand for drilling/clecoing.
Longerons clamped into place.
Using the bar clamps on the fwd fuse.
Here you can see the edge of the gear tower cover isn't quit reaching the vertex of the longeron.
