Brent s RV-8 Project N784DE
Date:  5-15-2008
Number of Hours:  1.20
Manual Reference:  Mod
Brief Description:  Instrument panel access modification #6
I finished up the fabrication on the avionics access modification this morning. I match drilled the door to the hinge and the bulkhead (at the nutplates) and then deburred, dimpled, and primed when I got home from work. Tomorrow I'll rivet it together and get back to the plans and forward motion on the fuselage.
Match drilling the access door to the hinge.
Here's what it looks like from the avoinics side (you won't see this once it's installed.
Here it is in action.
