Brief Description: Fuselage Forward Sub Structure #2
Mary and I did a couple of things on the fwd floor sub structure. She helped me remove the blue plastic from the aluminum and I deburred the edges of everything. Then we cleco'd together the stiffners to the forward baggage floor. The two inboard stiffners (F-870D-1) are diffent orientation from the drawings (dwg 63), but there is no other way for them to go based on how the plans showed them to be trimmed and where the holes are. I don't think it matters which side the web of the stiffner is on, but it is definately different. I believe Jeff Preou, ran into this so I'll go check out his website to see how it worked out.
Mary helping pull plastic off of the fwd baggage floor.
All of the part that we are using so far are ready to cleco together, etc.
